Help with ETKA needed
  • bartolomeus
    • Jan 2009
    • 1475
    • Country: Romania
    I already started 2 threads regarding ETKA so I will start this thread as a general thread in case somebody else needs some help with ETKA.
    At this time I need the part numbers of the nut, screw and washer basically everything that comes on the headlight in the point I indicate with my finger.
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Can you use a spire nut??
    • kninio
      • Aug 2004
      • 641
      • Home: Lebanon Current: United States
      is it what you want?
      • bartolomeus
        • Jan 2009
        • 1475
        • Country: Romania
        Well yes I can use a spire nut, it had one in the first place but it was all rusty and I decided to buy new.
        • kninio
          • Aug 2004
          • 641
          aha , i cant find part number for this u have on hand but its available seperatly
          • kninio
            • Aug 2004
            • 641
            http://www.ecstuning.com/Audi-80-Qua...ed_Nut/ES4787/
            check this one , if same dimension , then here is the part number N0154391
            • bartolomeus
              • Jan 2009
              • 1475
              • Country: Romania
              Hey kninio, thanks for your help.
              The spire nut you showed me it's not good
              Can anybody find me the part number for spire nut?
              • bartolomeus
                • Jan 2009
                • 1475
                • Country: Romania
                Anyone not so bored to look the part numbers for the screw, spire nut and washer if any for the S2 turn signal indicators?
                • sidrick
                  • Jan 2011
                  • 1342
                  Does vagcat.com not work for you?
                  Edit: That's not supposed to sound sarcastic
                  • bartolomeus
                    • Jan 2009
                    • 1475
                    • Country: Romania
                    Hmmm... Actually it helped me
                    Never knew about this website. Thanks mate!
