please,where I found VIN codes on audi S2 coupe? and how many are?
VIN code locations-help
There is the main stamped number in the bulkhead at the rear of the engine bay.
There is a plaque with the number near the fusebox on a RHD car.
Then depending on how original the car is.
There are numerous stickers around the interior and boot of the car with trim codes, chassis numbers and build dates etc -
VIN No. location and Build Tag info
In addition to the number stamped on the front edge of the scuttle (see 1st photo below), you want to find the build tag if you want to check out the options that your car came with (see 2nd photo)
Example Build tag locations: http://forums.quattroworld.com/s4s6/msgs/198304.phtml
Stamped VIN:
Example build tag (not an S2):
