Got arons CF cover here to go on, but cant even manage to get the old one off. What do i NEED to get off? Tried loosening the PAS belt, but that didnt help. Can't get the pully off the pump as the small radiator is in the way. Any tips?
Cambelt cover swap.. Help please
Tags: None -
Not sure about the ABY but with the AAN, you cannot remove the upper belt cover unless you remove the serpentine belt tensioner.
94 UrS4 V8 6 spd manual avant -
Not the same on an ABY... This was/is a proper biatch! Will do a write up later when i am not totaly knackered!Comment
