Attaching RS2 bumper
  • Sonic
    • Jul 2006
    • 5514
    After "shaving" back the corners of the RS2 bumper to avoid it catching the tyres, where you normally attach them with a screw by the wheel arch (not that that ever worked), the bumper hangs down quite a bit, exposing the rusty wing panel behind it and looks pretty silly.
    I attempted to fill it with glue to at least hold it in place whilst i was at spa, but this barely made it down the road and i resorted to good old cable-ties for the trip, attaching them round the corner of the bumper and through a hole in the wing, but even these didn't hold and regularly snapped having left lovely marks on the bumper.
    I can't think what else i can do besides duck-taping it up, but that's not an option.
    Any ideas?
    S2Forum.com Administrator
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    How about some photos?
    I could assume what you could do is use a small metal bracket between the bumper plastic arch piece and the fender so that you can attach flat screws and hold it inplace while making new holes on the plastic piece of the bumper
    • Sonic
      • Jul 2006
      • 5514
      I'll get a better photo in a bit as its hanging down a lot more than this now.
      I think some kind of bracket is properly allow it to be fastened to the wing is the best way for sure.
      • Rusty
        • 18953
        I drilled 2 small holes in the bumper and wing, where you can't see and cable tied it. Still attached 7 years later.
        • Sonic
          • Jul 2006
          • 5514
          Nice idea, i've always thought about looping the tie around the end of the bumper, not drilling 2 holes and going back through it with the tie... good thinking
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            Yes that is what I have thought but with screws rather than tie wraps. But if it works it works!
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              New bumper and some 225s?
              SS
              • Rusty
                • 18953
                Wide arches and 255s...
                • Fat Audi 80
                  • 10547
                  The Perfectionist
                  • Sonic
                    • Jul 2006
                    • 5514
                    I almost wept when I cut the rs2 bumper, but then I remembered i was ripped off by jay and Corey and as will said - you either take a pretty car to Spa or a functional one.
                    I think us have to get the Reiger replica if I was doing it again.
                    • John B
                      • Apr 2008
                      • 926
                      This is kinda like shaving and nicking yourself except a whole lot more expensive
                      That didn't help did it
                      Doh!
                      2001 996 C4 - Being renovated
                      • Sonic
                        • Jul 2006
                        • 5514
                        The other idea recommended is an aerocatch fitting.
                        That would work well.
                        • chezz
                          • Apr 2007
                          • 440
                          Probably irrelevant, but there is a mounting bracket close to the wheel arch, that sits on the wing - behind the bumper...I'm pretty sure that this component is different on the RS2's - if have not changed it, then it may be contributing to the poor fitting etc.,
