Today I was working under the bonnet when I noticed that around both of the turrets of my B4 I could see cracks in the seam sealer that are where the turrets meet the firewall (the seam sealer is in the 90 degree angles between a turret and the firewall)
They are present on both sides, go almost non-interrupted for about 20-30cm in length starting on top of the turrets (where the top mount caps sit) and go around the turrets down the firewall.
I haven't noticed them before, but this doesn't mean that they weren't there. They are less then 1mm thick, mostly hairline at most places.
Should I be worried or is this something that happens because the body flexes and the old seam sealer with hard paint on top cracks?
I have delrin control arm bushings, solid aluminium subframe bushings, stock springs and koni front shocks only one click away from the softest position. It's harder than stock but comfortable setup, no harsh hits when going over bumps.
It's also a 4 cylinder engine, so not that heavy. I am not the person that goes easy on their cars, mine is even lifted, but then again, I haven't done anything that hard to the chassis to crack it...
