removing a bumper
  • tony-t102
    • Oct 2004
    • 34
    removing a bumper
    Any tips on removing the front bumper on my 94 Avant. I haven't had a look at it yet but I'm going to tackle it today. Cheers.
    1994 S2 Avant Red. Home Fry. 100k.
  • rotoryboy
    • May 2004
    • 3281
    Dead easy. Indi's out, fog lights out. See 2 bolts behind the fogs (or where they were) remove these, undo clips/screws at either wheel arch (be careful not to snap) then unclip the undertray from the bottom of the bumper then she will just pull off. You will then have to disconnect the washer pipe, then she's off. Good luck
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • Graham
      • 1622
      First it is easiest if you remove the plastic under tray. Then in each front wheel arch there is 2 bolts which are torx bolts, undo them and remove them. Remove the indicator which is a single screw on the outside corner will also give you access to the fog light retainers. Now undo the Foglight bolts and carefully remove the fogs. Behind the indicator and fog lights there are four bolts. Sit on the floor with your legs under the car to prevent the bumper dropping and being damaged. Remove the four bolts and the bumper should then just about fall off, but dont pull it away as the headlight washer pipe then needs disconecting- I did mine at the Tee Piece behind the middle of the bumper. Carefully release the sides by gentle pulling, and lower the bumper till its on your legs. Then pull it forward and away.
      HTH
      Graham
      • Graham
        • 1622
        Damn- you beat me
        • rotoryboy
          • May 2004
          • 3281
          Ha thought there would have been loads of posts here as we can all do it in our sleep now
          Mark
          Race Clio RS197
          • tony-t102
            • Oct 2004
            • 34
            Yeh, I'm sure I'm going to get quite a bit of practice at it soon too. I'm Looking for a boost leak you see and I wanted to take the bumper off to check the intercooler pipes. I've made a pressure tester so hopefully that should show up any problems if there is a leak. It's really anoying me now
            Anyway, cheers for your help. I don't live that far from you guys actually, is there many north east meets?
            Tony.
            • Jas11n
              • 5067
              Tony.
              Hello Tony.
              There's a few of us up in the North East Few of us meet up regular.
              Really must organise a big meet this year.
              North east clan so far :-
              Me,
              Rotoryboy,
              Graham,
              Tekkno300,
              Mak2503
              Armo750,(my brother)
              Salmon,
              Bob69..
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • Graham
                • 1622
                We'll Have to got together for a winter photo shoot in a few weeks, we have a few pressure testers in our group what i made and they make most leak finding easy on the main system (all the major pipes, Intercooler, Turbo and Bypass valve) The small bore tubing is also one to look out for, most of the original fabric coated stuff decays and leaks like billyo, but it is easy to replace all of this with new.
                • tony-t102
                  • Oct 2004
                  • 34
                  Sounds good to me Graham. I got my car about 3 months ago from a forum regular which was good coz I could see it's history. The only thing is, is that the rear windows have been quite heavily tinted. Have you heard of any ways of removing the tinting film? It seems like quite a good job. Any way, heres some pics. URL]http://193.0.234.78/891010000407.jpg[/URL]
                  • tony-t102
                    • Oct 2004
                    • 34
                    well that didn't work, I'll try again....
                    http://images2.fotopic.net/?iid=ys72r3&outx=800&oq=0
                    • BRY
                      • 3755
                      How far north and east do you have to be to join the north east gang?
                      There are three of us in / around Sheffield with Avants.
                      • tony-t102
                        • Oct 2004
                        • 34
                        I dont know mate, I a bit of a newie so best let one of the other guys answer that one. I'm from Teesside and I think some of the others are too. Cheers.
                        • Graham
                          • 1622
                          I am from Eston, and there is no rules to be in the gang, well to be truthfull its not a gang as such, more a convenient meeting area as traveling south to meet all the rest of the folks on here is inconvenient for us Up Up Northerners. So it is convenient if we all make use of one anothers knowledge, and we do alright. When we meet it was last time at Scotch corner on the A1M, which is only 30 minutes away for most of us, and its easy to find.
                          • Graham
                            • 1622
                            BTW the last meet involved flying from Penrith to Scotch Corner in about 20 mins, (all private roads etc)we slowed once for Johnny Law to sub warp speeds, and also got some good pics of the cars.
