S2 coupe wing bottom torque screws?
  • mac2226
    • Jun 2008
    • 1289
    Hi I'm bit confused here as I've had my front s2 coupe wings of and there's two torque screws t10/15? I've forgot where I've put them I've been to Audi and there system doesn't have two screws I'm after are these genuine oem screws? Can some one tell me the size please as I need it doing ASAP thanks
  • S2TORNADO
    • Jan 2008
    • 620
    i think they're the ones right at the bottom of the wing, literally at the top edge of the sill. you need a long thin screwdriver to reach them between the small gap. You need to lay on the floor with a torch to look into the gap.
    • mac2226
      • Jun 2008
      • 1289
      Hi Andy I've got them out already but the trouble is don't no where I've put them went to Audi and doesn't show up on there system just the foam piece that shows up on picture I need to no what size to get before screwing a random screw inside
      • Nuvo
        • Nov 2003
        • 3825
        Part number is for the lower wing screw is N 013 969 4. It may have been superceded, but they should be able tell you that. They should also be able to find it on their system too.
        There is also a corresponding washer shown : N 902 056 01.
        • mac2226
          • Jun 2008
          • 1289
          Thanks Nuvo
          • shaun5
            • 1610
            I'll have the correct screws if you require them and the foam pieces that are in front of them.
            • mac2226
              • Jun 2008
              • 1289
              I've got the foam pieces thanks it's just the screws I'm after shaun5 will let you know by Tuesday if there the correct ones I've ordered thanks
