Are these two components interchangeable on the saloons? Cheers.
B3/B4 Saloon Wing Interchangeability?
audi /vw are some "#%%@ with parts; they do look alike, but dont fit.... why make so mutch different part in the same year and modell.... i was a volvo guy before, where you kan park the old car beside the 10 year newer,, and parts will fit,, same as opel, and ford... but audi vw... no way....you cant use some little parts, you need the hole ****....( fx.. the front end for the engine and tranny mounts.. think there are 5 or more different versons....) and the strut too... and 3 different bearings, 4 or more differnt brake kit... why????Comment
I first found out when I fitted a cq bumper to my 90q20v, the bumper could not go back far enough to line up with the arch (ignoring the flare). I cut the bumper and the mounts to let it slide back far enough to line up.
Most of the B4 front wings I have seen fitted to B3s have had b4 coupe/s2/v6 bumpers fitted at the same time.
It means you can run a bit more rubber.
Other thought would be wheel arch diameter, b3 uses 205/50/15, a b4 is 205/60/15 iirc.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
the subframe are similar; some detalj skills, for the 4pot, for dieselengine, for v6, for the 6tr tranny... but subframe will fit in car..( s2 from 91/ as 92 mod did have the 12mm bushing senter).. the subframe will also fit all mod of vw quantum/ santana versons...Comment
