Decided to change one of the door seals today. This is what i found on removing the seal
door seal 002.jpg door seal 004.jpg door seal 005.jpg door seal 006.jpg am i correct in thinking that this could be the main cause for the bad water leak i have on this side as there are two sizes of rivets a couple of rivets missing and the screws in the b pillar trim where rivets should be, someone has done a botch job. Question is was any sealant applied in these areas at the factory.
