Audi S6 Avant 1995-1997 (C4) Rear Logo Placement info required
Hi all,
does anyone know where exactly to place the rear emblem on an Audi S6 Avant (C4) 1995-1997? Precise distances from the respective edges are needed.
Thanks in advance for the valuable input!
Regards,
Michael
Regards,
Mike aka DontKnowler
Audi S4/6 AAN Avant
ML 55 AMG
Hi all,
Regards,
Michael
The rings in the middle? Or S6 emblem?
'93 Audi UrS4 Avant LPG
Hi all, does anyone know where exactly to place the rear emblem on an Audi S6 Avant (C4) 1995-1997? Precise distances from the respective edges are needed. Thanks in advance for the valuable input!
Regards, Michael
Rear = lower left corner 22 mm from left edge of trunk lid (93, 94). Presumably 92 = upper right corner = 22 mm from right edge of trunk lid.
Rear = lower edge 15 to 16 mm above lower edge of trunk lid
Those came from my 93 UrS4 sedan. I just went out and measure the location on my 94 S4 V8 avant and the distance from the edge was 18 mm not 22. The distance from the bottom was slightly less than 15 mm. Here is an example from an UrS6 brochure:
Thanks a lot, but I already have the placement data for the sedan version.
My question was in regard to the Avant (=station wagon) version - that I did not find anywhere yet.
A reliable prooflink confirming that the Avant placement is the same would also do
Regards,
Audi S4/6 AAN Avant
ML 55 AMG
Thanks a lot, but I already have the placement data for the sedan version. My question was in regard to the Avant (=station wagon) version - that I did not find anywhere yet. A reliable prooflink confirming that the Avant placement is the same would also do
See above. (Edited since you read it).
Just measured my euro 1996 S6 sedan and the bottom of the badge is 18mm from the bottom of the boot lip, the top left corner of the badge is 33mm from the left hand boot edge and the bottom left edge of the badge is 20mm from from the left hand boot edge. Sorry this took me so long...
