Hi, my passenger side electric front window does not work, i have tried changing the switch, still did not work, it does not work from the drivers side either, and i take it that both front electric windows would be off the same fuse, as drivers side works.
If i were to change the "window mechanism/regulator" which i have heard mentioned a couple of times on the forum, is there a high chance this will fix the problem? does this "mechanism/regulator" include the motor or is the motor seperate!?
Thanks
Thanks
