water in footwell
  • water in footwell
    Can anyone help I am getting a pool of water in my drivers side footwell , I have a rubber mat down and it only appears to be on the mat the carpet it totally dry, so it would appear as if it's coming from under the dash .It also only happens when it is totally p***** it down. Also looking to buy the rubber seal that goes on the front of the bonnet on the b3 model.
    It's perfectly normal
      One of common places to leak is seal around bonnet cable and fuse box.try this
        Cheers Rikki finally got all my other leaks sorted and now this!!
        Thanks alot piotr I will check that out tomorrow.
          This
          1996 S2 ABY Silver
            Its not a leak, its the coupe foot spa. Its supposed to be there
              I should of got a free rubber duck with my coupe .
                Cumbria is not a good place for a Coupe' on a serious not as mentioned fuse box area
                  remove the carpet of rainy days and drive it... you will se where it is comming.. but its normal so wellcome to the acvarium club...
                    Yup. Just embrace it!
                      That physically made me LOL
                        Sunroof hole blocked . Get a length of .75 cable and feed it down it
                          Ha ha ha now I'm worried , I struggle with the doggy paddle.......
