Has anyone else had this issue??
My avant roof is stuck solid
Before i start to strip it can you recommend any tips.
I have allready tryed to open it via the Allen key in the motor and the motor works fine,i think the mechanism is seized,thanks
I had similar trouble with my sunroof. I have some pics of what to expect, if you do strip the sunroof, make sure you keep the positions of each of the drive cables and motor timed with respect to each other. You dont want the motor trying to close a closed sunroof.
