Exterior trim and badge part numbers and a availability
  • Addison_80
    • Sep 2009
    • 28
    I am starting to collect new genuine trim pieces and badges with view to get the car fully resprayed and replace as many of the aged trim pieces and badges as possibe but I'm not sure what is still available from audi. If anyone has purchased any of the following or has any knowledge of their availability could they please update the list below. Cheers
    Front upper s2 grill
    Front upper rs2 grill
    Front grill Audi rings
    Front grill S2 Logo
    S2 bumper lower grills
    Elipsode headlights
    S2 front fog lights
    S2 front indicators
    Audi oval wing badges
    Side repeaters (clear)
    Right hand wing rub strip
    Left hand wing rub strip
    Right hand front door rub strip
    Left hand front door rub strip
    Right hand rear door run strip
    Left hand rear door run strip
    Right hand wing lower trim
    Left hand wing lower trim
    Right hand front door lower trim
    Left hand front door lower trim
    Right hand rear door lower trim
    Left hand rear door lower trim
    Right hand rear wing lower trim
    Left hand rear wing lower trim
    Right hand rear outer light cluster
    Left hand rear outer light cluster
    Right hand rear inner light cluster
    Left hand rear inner light cluster
    S2 avant rear number plate surround
    Rear audi ring logo
    Rear S2 logo
    Not intending to replace all of this but thought it would be useful to have a list of everything in 1 place as a reference.
  • irishs2
    • Apr 2009
    • 2455
    Bad news on any S2 avant trim to be honest. Here is your list.
    Front upper s2 grill 8G0853651G 2ZZ €139+vay
    Front upper rs2 grill Dropped
    Front grill Audi rings 893853605
    Front grill S2 Logo 895853736B 2ZZ Dropped but Available from Audi Tradition
    S2 bumper lower grills 895853667E 01C , 895853683B 01C , 895853668A 01C
    Elipsode headlights Available €348+vat each
    S2 front fog lights 8A0941699 ,8A0941700 €146+vat each
    S2 front indicators 8A0953055A , 8A0953056A white €38+vat each
    Audi oval wing badges 8A0853621 2ZZ Dropped
    Side repeaters (clear) 161949117, Yellow only available from dealer.
    Right hand wing rub strip 8A0853508B GRU Dropped
    Left hand wing rub strip 8A0853507B GRU Dropped
    Right hand front door rub strip 8A0853958A GRU Dropped
    Left hand front door rub strip 8A0853957A GRU dropped
    Right hand rear door run strip 8A0853968B GRU Dropped
    Left hand rear door run strip 8A0853967B GRU Dropped
    Right hand wing lower trim 8A0853992B 3FZ Dropped
    Left hand wing lower trim 8A0853991B 3FZ Dropped
    Right hand front door lower trim 893853960B 01C
    Left hand front door lower trim 893853959B 01C
    Right hand rear door lower trim 893853970B 01C
    Left hand rear door lower trim 893853969B 01C
    Right hand rear wing lower trim 8A0853700A 3FZ Dropped
    Left hand rear wing lower trim 8A0853699A 3FZ Dropped
    Right hand rear outer light cluster 8A9945218 dropped
    Left hand rear outer light cluster 8A9945217 €76+vat
    Right hand rear inner light cluster dropped 8A9945224A
    Left hand rear inner light cluster dropped 8A9945223A (right hand traffic only)
    S2 avant rear number plate surround 8A9853465 3FZ Dropped
    Rear audi ring logo 441853742 Size 180x58.5 €27.40+vat
    Rear S2 logo 895853735B 2ZZ Dropped
    Eric
    95 S2 Avant under rebuild.
    • bilko0795
      • Feb 2011
      • 1883
      You can still get the oval wing badges from Tps just had some six weeks ago around £11 each.
      • Michael S2
        • Dec 2011
        • 1378
        As you can see from above, S2 avant ownership can be frustrating.
        Rear S2 badges appear on eBay sometimes but are £50 or something. I need one too but wont pay that. Are your rubber trims really bad? If not I suggest trying some trim restorer, works well on mine.
        While on topic how are the front grill rings supposed to attach? Looks like there should be some clip for the pins on the rear of the rings but im not sure.
        1995 Audi S2 Avant
        • irishs2
          • Apr 2009
          • 2455
          For the coupe yes, not the avant unfortunately.
          Eric
          • Addison_80
            • Sep 2009
            • 28
            Good effort. Wasn't expecting all that in one go!
            • MattS2
              • Apr 2006
              • 657
              I have some lower door trims for sale if you want them.
              I might even give you a discount as a repeat customer.
              Matt.
              Ex owner of a 1993 Silver Avant - RS2 spec.
              2002 A8 sport 2.8 quattro Sold
              2003 A6 Avant Tdi
              Mk Indy 2.0 pinto circa 160 Bhp
              2004 VW Caddy SDi
              2002 Civic Type R
              • Addison_80
                • Sep 2009
                • 28
                Haha! You determined to drain my bank? What else you got stashed? Might as well ask to cut down on postage!!
                • Addison_80
                  • Sep 2009
                  • 28
                  Trims are not that bad. The ends are a bit tatty but the strips themselves are fine. I'll get new if I can but would be interested to knownwhere you got yours restored?
