Rubber door-trim things?
  • John.
    • 2615
    I read somewhere on the forum that the rubber bits which sit at the top of the door(coupe) are available? Can someone point me in the right direction?
    They are the bits that contact the door seal when door is shut and it looks like they are bonded to the metal-work of the door, not part of the door card.
    I need 2, the rear ones for both doors.
    Thanks.
    This one should have the details you need http://www.s2forum.com/forum/showthread.php?t=72681 they are available from audi tradition.
    • Monkeymagic
      • Mar 2012
      • 3419
      At great expense for 4 bits of rubber. That said they look good
      • John.
        • 2615
        Cheers for that, if I went to TPS would they be able to get them direct from Audi Tradition if I give them the part numbers?.......I'm not navigating around the Audi Tradition site too well?!
        • Monkeymagic
          • Mar 2012
          • 3419
          Audi tradition only mate
          • John.
            • 2615
            Ok, thanks.
              The best bet is to buy a reasonable amount from audi tradition as shipping is expensive
              • John.
                • 2615
                I can't even find them on their web site, I'm putting in part no. 895 867 693 01C
                Using advanced search and putting the part no. in where it says "Articlenumber"
                • Bowie69
                  • Nov 2013
                  • 2675
                  Tried taking out the spaces?
                  • John.
                    • 2615
                    Just tried that........."Your search returned 0 results"
                    Ahhhhh!!
                    • irishs2
                      • Apr 2009
                      • 2455
                      Eric
                      95 S2 Avant under rebuild.
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        I recall emailing a chap called Sebastian funk I tthink it was to get help. I can't believe the Germans designed something that inefficient
                        • John.
                          • 2615
                          Cheers for that but ready to smash this computer up due to not getting registered on their site......will try later.
                          • Bowie69
                            • Nov 2013
                            • 2675
                            So it seems you need to just remove the last 3 chars to get it to work
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              Oic refers to the colour eg black.
