rs2 vs s2 body
  • vidar skotheim
    • Apr 2005
    • 566
    • Country: Norway
    rs2 vs s2 body
    Is the part nummber on a s2 and a rs2 body the same ?
    I can see most body parts are same on other audi "80" , buth i cant find out about the part nummber for complete body , want to get my s2 approved with 315hk , no problem if the rs2 body have same part nummber as a s2 .
    Suspension are rs2 big reds , only thing is i think the brake master cylinder is from s2 and the smal regulator vale under the master also is s2 i guess .
    Not sure exactly what you are trying to do but the build tags would be the final tell. The body shell of a B4 S2 ABY 6 spd avant would be the same as an RS2. Both are no longer available so their part numbers do not show up anymore.
    Generic S2 Avant build tag:
    Example RS2 Build tags.
    • caterpillar
      • 2480
      i think you will se the P/N in older etka versons ( may etka 6).. and s2 and rs 2 after 92 does have the 12mm bolts to the subframes ..
      • AndyP
        • 6049
        I'm using version 5.6 and it's still listed as NLA
        • vidar skotheim
          • Apr 2005
          • 566
          • Country: Norway
          Anyone have a older version ? i can see the parts that are stil llisted in the body nowe ( front details) are samoe on other audi 80 , would be nice to knowe the body nummbers , i guess i can ask the dealer in the city .
          • vidar skotheim
            • Apr 2005
            • 566
            • Country: Norway
            There is a body for sale on facebook with 8a5800403 ah , it does work on the etka when i put in the nummber
            • AndyP
              • 6049
              You'd have to find a version of ETKA from when the car was in production
              • vidar skotheim
                • Apr 2005
                • 566
                • Country: Norway
                http://www.partsbase.org/audi/audi-8...ud-8a5800403ah
                • vidar skotheim
                  • Apr 2005
                  • 566
                  • Country: Norway
                  8a9800403bj
                  8a9800403aq
                  8a9800403bg
                  8a9800403ar
                  8a9800403bh
                  8a9800403as
                  • vidar skotheim
                    • Apr 2005
                    • 566
                    • Country: Norway
                    So then missing rs2 number
                    • caterpillar
                      • 2480
                      audi 80 doesnt have the enginemount brackets; then its different PN, maybee..it was like the vw passat 32b...for the 5 pot
                      i did a rebuild from 4 pot to 5 pot....asked KRB or Dahlbeck ??...
                      • saltinot
                        • May 2004
                        • 1946
                        The S2 avant and RS2 bodies are identical.....no difference.
                        The wings/fenders/Kotflügel are identical also. The intercooler traverse is the only difference. Of course those are 'bolt-ons", but worth mentioning.
                        • irishs2
                          • Apr 2009
                          • 2455
                          There is a slight difference in the front wings, There is no holes for the lower oval audi badge on the RS2 wing, and no slot + hole for the s2 mid trim .
                          Eric
                          95 S2 Avant under rebuild.
                          • saltinot
                            • May 2004
                            • 1946
                            haha. I forgot about that one Eric. Good catch!
                            • vidar skotheim
                              • Apr 2005
                              • 566
                              • Country: Norway
                              I nowe they look same , buth i need some paper were it stands the rs2 body nr . From a old etka
