My 'not so' black trim
  • Jamie
    • Nov 2003
    • 83
    Any ideas on where I can pick up the lower half of the plastic trim (coloured black) which runs along the side of the car and the rear bumber. Does anyone know if this can be bought separately, or do you have to buy the entire trim including colour coded top half?
    Ive tried everything bar black shoe polish - back to black etc, to get rid of the white residue and blacken it up again.
    If Im looking at second hand parts, Im not sure its worth the hassle as they are likely to not be too much better.
    J
  • Mark Halligan
    • 2001
    Got mine from VAG parts for the doors on my coupe, as I remember fairly cheaply too.
    Mark - Modded
      I'm pretty sure you can buy this seperate from VAG Parts.
      There was a couple of threads regarding this knocking around the forum, also believe i Audiman has done this?
      • S2 Ant
        • 3682
        i need to do the same really, the sides are ok but that grey part on the bottom of the rear bumper goes all sorts of crappy colours!
        Ive been told of a supposedly really good black plastic paint that im almost tempted by
        Ant
        2011 Kawasaki Z1000
        • S2-racer
          • May 2004
          • 247
          i used some williams f1 back-to-black stuff from halfords that seems to last at least a week before fading again. not sure on a permanent fix tho
          '92 S2 - Bent now
          • quattronutter
            • Jan 2005
            • 690
            only cure is to repaint original satin black,if you want a permanent cure
            • Doug_RS2
              • 3847
              I am not sure if this will work - but on some cars - if you use a hair dryer on the faded black plastic it brings the blackness back
              • Jas11n
                • 5067
                Aye,,,that works,,,,well it did on my previous 2 coupes,,,,,
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                • ericd
                  • Nov 2003
                  • 1240
                  Try the Autoglym "green gel" aka Bumper Care, put it on a couple of days in a row to build up the colour back to the original, should get you back to blackish within a week.
                  • Beetie
                    • Oct 2003
                    • 1517
                    This should work. A paint/body repair man told me of this once. It get rid of the oxidisation on the top.
                    • Fat Audi 80
                      • 10547
                      Hi Jamie,
                      The side trims are available from VAG parts and I think I paid about £75 - £100 for a set of four: both doors and both rear lower quater panels. Easy to fit - 20 min job. When you get them give us a shout if you need any fitting tips.
                      Rear bumper is bad news - it is all one moulding with a "smooth" upper area that is painted and the "rough" lower section that is black. (or in your case grey )
                      I have used Autoglym plastic and rubber trim gel and that works very well. You will have to regularly condition it for a while before it keeps its black look, but it should go black again after a few weeks....
                      HTH
                      Cheers,
                      Steve.
                      The Perfectionist
                      • Jamie
                        • Nov 2003
                        • 83
                        Originally posted by Fat Audi 80
                        Hi Jamo,
                        HTH
                        Cheers,
                        Steve.
                        Thanks for the tips. I will basically invest in rubber trim gel, borrow the missus' hairdryer and get to work. Ill let you know the results. If not, VAG parts it is. Unfortunately the main discolouration is on that rear section - whole new bumber?...tempting.
                        J
                        • alg
                          • Apr 2004
                          • 1160
                          Always worked well for me too
                          Alastair
                          RS2
                          • Fat Audi 80
                            • 10547
                            I would be surprised if you need a new bumper. Be careful, I had mine done on the insurance after a neighbour hit it and the whole bill was about £600!!
                            Youi should be fine with the Autoglym.
                            Cheers,
                            Steve
                            The Perfectionist
