Coupe window replacement / adjustment
  • Rusty
    • 18953
    My window was dropping 1" or so at the front, so I decided to see what was up. Unfortunately, the cable had frayed and was down to 50% of the wires
    Anyway, I've replaced the regulator from a Cabrio, which appears to be identical and adjusted it all, so it's fitting the 'frame' nicely.
    Wierdly though, there is a 5mm gap between the window and the flocked trim, which attatches to the car, which gets wider from front to back.
    Could be a few things but wondered in anyone had any ideas? I can't see any adjustment other than to shim the window out.
  • Nuvo
    • Nov 2003
    • 3825
    Packing pieces or shims of varying thickness are used at the bottom of the regulator frame to adjust the angle of the glass in or out. Do you have these fitted?
    • LHD_Kid
      • May 2006
      • 3695
      Good luck with that - I did similar a while ago... Both sides
      For me, trial and error - lots of swearing and shimming.
      Mine was shimmed at the glass fixings and at the reg to door fixings. Lots of variables...
      I thought someone (Error404 maybe?) had located a proper Audi manual and could check on the "correct" alignment procedure ...
      • Rusty
        • 18953
        Lower shims are all there. The gap is fairly large compared to any adjustment. It's not the end of the world, just not neat.
        • Rusty
          • 18953
          Here's a pic of the gap. It's about 5 mm!
          • willg54
            • Jun 2009
            • 2055
            ever fix this? i have the same issue!
            • Rusty
              • 18953
              Nope and no leaks so not an issue for me at least...
              • willg54
                • Jun 2009
                • 2055
                so youve still got the gap when opening the door? mine closes up fairly well when its shut
                might get some more shims for the window
