It will always be slower when going up. I did the same with mine, greased all the cables, opened up the motor, regreased that and used loads of silicone spray on the tracks too.
'93 Audi UrS4 Avant LPG
It all gets gunged up. As above, pull it to bits, clean it all up and put new grease on. Make sure you note the position of the ends of the guides, as these have 3 notches that allow for tightening the cable.
I greased the runners with some silicone spray which improved things, but I need to take them apart and regrease the motors, but not in a hurry to do that as I know how much of a PITA it is readjusting the windows when they are refitted.
Another possibility is that the electric switch is on it's way out.
What happens is that the full current for opening and closing the window goes through the switch and the contacts get fried. Also: the switch can get wet if the door is opened when it's raining.
To test if it is the switch: Open the windows using the switch and close the windows with the central locking from the car by holding the key to the lock door position for x seconds. If the window(s) now close rapidly then it is the switch.
5 cilinder addict:
1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
1993 S2, 2.2 turbo, ABY, long term project.
2006 Ford Fiesta 1.4 TDCI. Because reasons.
Mine was slow for years David, when replacing the door rubbers I lubricated the rails and cables, no dismantling was required and it as good as new...
Steve
The Perfectionist
Good to know Steve, thanks. I am hopeful that a little fettling will restore them to new...who knows may even resolve the squeal you get when the weather finally warms up too
