Leaking fuel tank
  • alexqts
    • Sep 2012
    • 92
    Leaking fuel tank
    Fairly sure this is a leaking tank, but it seems more like a thick oil that is covering the tank, spare wheel well and the diff.
    I am mobile at the moment but made a folder on my google drive:
    Would appreciate opinions.
  • shaun5
    • 1610
    Tanks are known to leak, this is what i did to mine. I have got a spare one
    • spink
      • 4382
      Diff oil will be leaking past the seal,very common
      If it's also smells of petrol then probably leaking aswell but the only place I've known them leak is on the passenger side of the propshaft on the vertical face,easy checked by pulling away the covering
      • alexqts
        • Sep 2012
        • 92
        I will have another look tomorrow. I just couldn't work out how so much oil / fluid had gotten above the diff so to speak. Will try and clean it up carefully and watch when it comes back!
        Don't suppose you have any decent fuel lines kicking around do you? It's the one with 3 lines heading to the tank (4A0201544A I believe), might have to make some with copper / rubber. I just keep finding bloody rust!!
        • alexqts
          • Sep 2012
          • 92
          http://www.s2forum.com/forum/showthr...t=74147&page=4
          Time will tell if mine is leaking, but as soon as I have the car back on the road I am hiring a lift to sort out the underneath. Presume you have to drop the subframe to replace the tank?
          • quattrostyle
            • Oct 2006
            • 6229
            That looks bad! I would replace them with some plastic fuel lines.
            • AndyP
              • 6049
              What car is this on?
              • spink
                • 4382
                UrS4
                Yes Alex,subframe needs to come off to take off tank,along with diff
                It's not a bad job on a 2 poster though,I did the one on my s6 a couple of years ago in an afternoon (I was feeling especially motivated that day lol)
                I have heard of garages quoting mental amounts £800-900 to do it
                I don't have any good lines I'm afraid,I use cupro nickel line to replace them.
                Btw the flared connections at the bottom of the bulkhead are quite large and I borrow a kit for making brake lines for trucks to match them
