Lower door rubbers different sizes
  • andyg plym
    • Nov 2006
    • 4646
    Evening all
    So I cleared the shed out today and came accross my spare set of lower door rubbers that I kept from an s2 I broke ages ago, to my horror I found the rears a good few inches longer than my tatty ones on the car.
    They also don't sit flush on the door, they stick out quite a way, il get some pictures soon but I'm guessing on the s2 the door has a slight recess on the bottom? Mine are flush all the way.
    I can get them to fit with a bit of trimming etc but was never aware they came in different sizes?? When I removed the spare set from the donor car there were never any issues and they sat perfectly!
    Anyone else come across this? From memory the donor car was a '95 and mine is a '93
  • mcandmar
    • Apr 2004
    • 5118
    Pics
    I was looking at how ratty mine are today and had a browse through etka, seems there are two regular versions, and another set "vehicles with widened sill panels" listed for the S2. Wouldn't mind some clarification before i order some new ones.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      Originally posted by mcandmar
      Pics I was looking at how ratty mine are today and had a browse through etka, seems there are two regular versions, and another set "vehicles with widened sill panels" listed for the S2. Wouldn't mind some clarification before i order some new ones.
      Hmm....I just saw that the 895853959A was the correct lower left door trim from 1989 to 1996. (960A right)
      • mcandmar
        • Apr 2004
        • 5118
        Look under 80Q, not coupe
          Sorry. I couldn't really see Andy's car in his avatar there. That said "rears" should have been the tip off.
          Now I see it (them) 893853969B S2 left rear (970B - S2 right rear)
          • andyg plym
            • Nov 2006
            • 4646
            More pics coming I appear to be having some difficulty uploading
            • andyg plym
              • Nov 2006
              • 4646
              [ATTACH]54267[/ATTACH]
              • andyg plym
                • Nov 2006
                • 4646
                [ATTACH]54268[/ATTACH]
                • mdz
                  • Jun 2012
                  • 775
                  • Country: Latvia
                  Looks more like B6/B7 or C5 trim. Definitely not a B4 saloon/avant trim.
                  • andyg plym
                    • Nov 2006
                    • 4646
                    These came off a 1995 S2 Avant that I broke
                    • bluequattro
                      • 2960
                      Shouldn't there be a small one by the rear arch?
                      Those certainly look too big, more of a c4 size
                      I think I have some s2 ones still, will check against an s2 and my 80 avant quattro
                      • gag4o
                        • May 2015
                        • 76
                        • Home: Bulgaria Current: United States
                        Andyg check the part Number on both and see what is the difference.. I am guessing there might be a difference for S2 avant and non s2 avant, or different sizes for 91' and 95'
                        99' BMW 528iT (the Bear) - sold
                        07'-09' Linkoln MkS 3.7 (the Limo)
                        94' Audi 90 CS 2.8 (Barak Obama) -Dissasembled donor
                        97' Cabriolet 2.8 (Kremena) - sold
                        97' Cabriolet 2.8 (Albena) - the One
                        • andyg plym
                          • Nov 2006
                          • 4646
                          So getting impatient trying to find a set of decent door lower mouldings, do ones off an 80 fit ? When I've been looking the problem is the track on the back of the rubber itself, my s2 ones are very shallow and the 80 ones appear to be deeper ? So will stick out further. Can anyone confirm ?
                          • JariP
                            • 192
                            The S2 avant/limo door mouldings are atleast the same as 89-91 Audi 90 door mouldings, excluding the end/wing pieces. Early b4 80 (91-92) might have the same ones too. Mouldings from b4 80 (93-94) do also fit but they don't match the S2 moulding end pieces . S2 one's are quite flat, 80 ones are much more bulkier or fatter. Aren't they available from audi anymore? They weren't grazy money when I bought a set couple years ago.
                            • andyg plym
                              • Nov 2006
                              • 4646
                              Thanks jari p that's a great help.
                              P.s still have your box , diff, shafts ,carpet here safe and sound
