Rust killer
  • pasbogdan
    replied
    Clean the rust with wire brush on the angle grinder or on drilling machine.If in the process the area gets black collor means the only way to get rust out is sandblast etc.Best way on 100% clean metal is to use epoxy primer with a layer of paint.
  • GT500
    replied
    Originally posted by Error404
    Just had a dig about, those 1kW units are $480,000
    I'll sell the RS2 and buy one. 😊
    replied
  • GT500
    replied
    Holy ****! That thing is awesome!
    Yep. Where do they sell those?
    replied
    Originally posted by Sküll
    in a couple of years we`ll all have this at home:
    https://www.youtube.com/watch?v=CLaBFkeHG0A
  • Michael S2
    replied
    Have used bilt hamber and it does a great job. Have got loads leftover if anyone wants it.
  • AndyP
    replied
    Originally posted by Bowie69
    Primer + Stonechip is NOT water/oxygen proof....
    As above, use a proper top coat, and THEN think about using a stonechip if it is vulnerable to that.
    This maybe the issue, primer I knew wasn't waterproof, but I assumed stonechip was. I'll strip it off and put some top coat on before stonechipping again.
  • hiloran
    replied
    I have used http://www.bilthamber.com/corrosion-...ments/deox-gel
    Spread, leave it for short time, brush, wash few times and it is good for primer.
    Best would be: http://www.bilthamber.com/corrosion-...atments/deox-c
    but I´m not sure if you want to dip your car
  • Skull
    replied
    Originally posted by hunker7
    Apparently they cost way over $100k so I doubt that
    i said in couple of years, by then the chinese will be making them and youll get them for £50
  • hunker7
    replied
  • vonbeck
    replied
    Hi Andy i`ve used this
    Hydrate-80 is a rust converter which provides unparalleled protection to rusted steel surfaces.
    they do some pretty good stuff
  • Skull
    replied
  • gnutz2
    replied
    Depends on what primer you use.
  • Bowie69
    replied
  • diesel des
    replied
    Originally posted by imp998
    https://www.youtube.com/watch?v=WgiecR6LzwA
    Not tried one but they look s**t hot
    It's not leaving much of a prepared surface like blasting does. A sa of about 3 is ideal and easy to get with blasting.
