RS2 keys??
  • Rs6fan
    • Jul 2015
    • 15
    RS2 keys??
    Do they have a separate key for ignition and another for the doors??
    No, unequivically.
    But you can change the tumblers in say the ignition lock barrel to match the doors and boot lock.
    This may be difficult for you but it is possible.
    HTH.
    • fourringsrus
      • Oct 2009
      • 239
      Only if locks have been changed previously
      • Rs6fan
        • Jul 2015
        • 15
        How do I change the tumblers in the locks?
          Consider this:
          1. There is only one ignition lock but it is difficult to access, including drilling a hole in "secret" location on the steering wheel lock
          2. There are three door/hatch locks but they require dismantling the door/hatch trim to access them.
          3. Rekeying might require new/additional pin guides (slotted metal bits that control the"tumblers")
          My quick answer based on the above is "live with it" or alternatively, install a Right Click radio frequency remote on your RS2's lock control module and normally not worry about using your door/hatch lock key.
