Coupe rear reflector removal.
  • Monkeymagic
    • Mar 2012
    • 3419
    Ever since I've owned my coupe mine has rattled. How do I remove it to check what's going on.? I can see two 10 mm studs behind back panel trim but I've only had a 2 minute look. I'm going to attack a few jobs this year. IM injector seals etc/front rear subframe bush renewal and a couple of other little niggles. Cheers Steven
    Yes two studs mate. There is often some double sided tape. From the factory there were two foam pads to stop the rattle, they have probably disintegrated or squashed flat.
    • Monkeymagic
      • Mar 2012
      • 3419
      Excellent. That explains why the studs appear tight but it rattles. Many thank Alex.
