Both door locks with the key are not triggering the factory alarm with its unique"honk".
From experience without these working it will be a problem if ever the battery need disconnecting and not being able to reset.
What would be the main culprit in not activating the immobiliser.Have a full set of doors in the shed,so can pillage parts.
Is there a sensor on the key lock which could be causing this?
Cenral locking works fine on the key
