UrS6 - How to 'Grease" the Door Window Tracks ?
    Hi,
    My off side rear electric window must be a bit stiff for the motor as it more often than not stops at 3" before fully shut.
    I presume that a sensor / the window motor thinks something is stuck in the path of the window and therefore at the stop point it automatically re-opens as a safety measure.
    I don't want to take the door apart, but I still want to grease the window track to ease the movement of the window.
    What is the correct lubricant to use in the 'furry' window tracks that will work, but not damage / compromise the door seals ?
    Thanks.
  • Rudpavv
    • May 2017
    • 15
    • Country: Poland
    I used silicon grease spray can on my B4 and everything was fine. Just don't use oil based grease because it damages rubber
    • daren
      • Apr 2008
      • 38
      I've used spray furniture polish before
      Told to remove my signature
      • fourringsofhappiness
        • Dec 2013
        • 40
        I went through a slow rear window regulator. I ended up..
        pulling the motor and lubed the white gear/wire assembly behind it. Quite and quick now.
