Door sill plate removal
  • tommyb
    • Aug 2016
    • 14
    Hi.
    Has anyone got a method of getting these off for painting inside of the doors? One is damaged anyway. Can I get replacements?
    Sent from my SM-G920F using Tapatalk
    They come off with a (low) heat gun and a scraper *BUT* not in one piece. You didn't say which car. I know Audi Tradition had made new C4 (4 dr) plates.
    C4 = 4A0853491 Left, 492 right. Scuff plate outer - sill panel (self-adhering).
    S2 2dr = 895853491 Left, 492 right. Scuff plate outer, also use (D 438 515 A1) which I would take to be a contact cement
    • tommyb
      • Aug 2016
      • 14
      Off the S2. Cheers.
      • nip
        • Apr 2006
        • 1786
        • Home: United Kingdom Current: Abu Dhabi
        I used a hairdryer come of easy, take your time so they don't break
          As has been said. Low heat gun, if you are very lucky it wont break
          • bluequattro
            • 2960
            Can get new for cabriolet which fit coupe
            I had some from TPS in November.
            Wallet busting price though. I seemed to remember £170 ish a side
            • tommyb
              • Aug 2016
              • 14
              Ok thanks. 😨
              • diesel des
                • 3896
                Wonder if Audi tradition still have these for a urs4? And at what price?
                Sent from my Moto G (5) using Tapatalk
                • tomwood_uk
                  • Feb 2009
                  • 336
                  I got one from TPS a couple of months back, £90 a side on trade.
                  • steve briance
                    • Aug 2014
                    • 1455
                    its crazy money for what they are. Mine went the same way as yours and i peeled mine off. It broke a lot and underneath was pretty grubby with mud stuck where you couldn't see it.
                    I got some thick exterior grade adhesive vinyl in satin black and used that as a replacement.
                    Yes it isn't factory but it does actually look alright if you take your time applying it and it costs pence, wears alright, won't shatter and can be replaced for pence as well. I figured the plastic was there to protect the paint and then thought how much abuse does it actually get? Not much is the answer as my vinyl is still good after a year.
                    • popdemonic
                      • Dec 2007
                      • 1304
                      • Country: Thailand
                      i'm going to replace mine too.one side of it has a small chips on the plate.
                      one of a few I5 from Asia.
                      • s2driveruk
                        • 12696
                        £170 per side, thats insane pricing!
                        1992 3b S2 Coupe
                        • tommyb
                          • Aug 2016
                          • 14
                          Tomwood uk.
                          Do you have the website and part no. For tps? Thanks.
                          • tomwood_uk
                            • Feb 2009
                            • 336
                            Originally posted by tommyb
                            Tomwood uk.
                            Best to give them a call, trade part supplies (i believe)
