small dent
  • Ski
    • 2591
    small dent
    small dint.
    I have a small dint in my drivers front wing
    I know it aint the end of the world but i like my s2 perfect.. seriously p*ssed off and want to hang the person on a tree who is responsible.
    Anyway, yes the dent... its above the wheel arch where the curve is that runs down the whole wing. if I pop my bonnet, its on line with the "end" of the airbox.
    Is there anyway I can remove the "inner" wing so i can try and push this dent out? I see bolts holding it together, but IM guessing I have to take the whole air box out first? anything else? Would I be better to get a dent wizard out?
    GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRR
    ABY Coupe
  • Fat Audi 80
    • 10547
    Dentmasters or equivalent is your best bet. I have heard good stories about some of them. See if you can get a recommendation for your area.
    Cheers,
    Steve.
    The Perfectionist
    • Ski
      • 2591
      Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!
      ABY Coupe
      • Ski
        • 2591
        the only place i can find is a "dent wizard (UK) ltd" but its based in sutton coldfield.
        Anyone know any alternatives? Think they said £85 per pannel :/
        ABY Coupe
        • Ski
          • 2591
          ok found dentastic in my area... 07958573234 around £50.
          will try to fix myself first
          ABY Coupe
          • WabTheKing
            • May 2004
            • 2567
            Dr. Vynal
            Stuart Rd
            Bredbury
              Cheers for that just down the road
              • Ski
                • 2591
                hee hee
                ok back to my original small question, is there anything complicated about taking out the inner wing of the drivers side? I see a few bolts on top.. anything else?
                ABY Coupe
                • Ski
                  • 2591
                  no have an idea how the inner wing is mounted? maybe someone has a parts diagram ?
                  ABY Coupe
                  • gavs20v
                    • Sep 2004
                    • 3057
                    Do you mean the plastic arch liner inside the wing or the actual inner wing itself? The inner wing is welded in place not bolted, might be easierto remove the wing completely giving you easy access to the damged area, if you do becarefull and remember to to take the screws out at the bottom of the wing where it joins the sill. Youll need to pop the black plastic trim off then have a bit of a clean up behind there to see them.
                    HTH
                    Gav
                    S2 Cabriolet.........
                    • Ski
                      • 2591
                      crap!
                      I saw bolts and thought it would simply "unbolt" free. Thats just rained on my parade!!
                      I just need access to the inside of the wing to push the dent out, just above the wheel. Any other way?
                      ABY Coupe
                      • Ski
                        • 2591
                        just found out i can gain access to inside of the wing through the wheel arch. Will give that a try first
                        ABY Coupe
                        • gavs20v
                          • Sep 2004
                          • 3057
                          Only other suggestion would be to remove the arch liner and the wheel and see if you can access it that way. How big is the dent ? can it be pulled out by one of those suction cups? has it just been pushed in or has the metal actually creased? if its been creased id give it to a bodyshop too sort. Removing the wing isnt actually too much of a ballach to be honest, worst bit releasing it from the sealant Audi used to seal it agains the inner wing
                          Gav
                          • Ski
                            • 2591
                            cheers gav.
                            yeah no scratches, and its dinted along the curve in the arch, so unfortunatly it cant be sucked out and it looks like it will pop out quite easy (i hope)
                            ABY Coupe
                            • gavs20v
                              • Sep 2004
                              • 3057
                              cool, fingers crossed mate
