Audi s2 600hp structural support?
  • Audi s2 600hp structural support?
    Hi gents,
    My audi s2 is soon going to be fully restored and wanted to know if there is some essential support needed to the chassis to run this sort of power?
    I am struggling to find a topic on this.
    This is appart from the obvious:
    Power flex threwout
    Coil overs
    6pot uprated brakes
    Fat wheels
    Engine mounts
    Uprated arb
    ​​​​​Cheers
    Also drive train mounts are a must.The oem Front antiroll bar can be used on back as a cheap upgrade you have to switch suspension over,so left leg on right and right leg on left for it to fit. Drop links I used rs2 I believe long time ago but theres a thread some where. Also your top mounts could do with replacing while suspension is of the car for new shocks and springs unless your going coilovers then I would go with kw but that’s my choice. 6 pots for bolt on solution Porsche Cayenne with 330/360mm depending on your wheel clearance and the caliper you choose as there’s two different calipers 17zr/zl use smaller discs but bigger pistons or 18zr/zl bigger discs smaller pistons. Brackets are easy to get hold of.
      Ah I see.
      I do have the v6 arb which is thicker and what I wanted to use. Yea there zr17 360mm I think roughly
      Definitely going kw coil overs
      Want close to std look but quite hard for performance
      Oh you mean box and diff mounts?
      Thanks for help mate
        what turbo are you going to use?
          Am compound setup gt2560r with gt3082r something a bit different.
          ​​​Forged engine with gurdle.
          I have 5speed 01e running gear
          Box is in for reconning as we speak
          Not going full boost as I haven't got the lager 2nd gear!
            I have a set of 18z with brand new disks and used pads for sale with brackets .
            Just had them painted yellow
            pm me if your intrested.
              nice cant wait to see some pictures
                Cheers for the offer mate but
                I have a set with vented dimpled and grooved rotors and porsche 6 pots, need 18' bbs for these bad boys!
                  Definitely will mate
                  I will open a project thread, once I get the 3b running on emerald with smart coils.
