Afternoon all, what a pleasant surprise to find a new fab's section. I thought I would kick off with the first of many fabrication sub projects for my S2 coop resto / budget track build. I have a big interest in fabrication & machining and love to make my own things so I thought I would make a start by designing my extended shifter, work on the car has been touch & go due to the weather being awful so whilst the rain pours I have been busy behind my CAD screen with a brew.
The first revision of the shifter was quickly improved upon, here it is just for the hell of it.
Now it know its not a completely original design but hey, it'll work. I decided to preload the central pivot so it doesn't rattle about when the car is driven, this lead to the following changes......
Different CAD screens as I like to a bit at work
We use Bentley powerdraft here which is *****! AutoCAD ftw.
So that's what it looks like, it still needs some thought about the reverse lock out actuation but it will likely be a lever of some sort to pull the pin back above the central pivot.
The actual shifter shaft is about 400mm long, the throw has been reduced to almost half of a stock shifter hence the pivot height has to be raised above the tunnel to acheive this, I plan to design it so that I will bolt in to any S2 & maybe B5 shifter cut-out in the tunnel.
Now to the actual construction. All the shafts will be made from silver steel and retained with circlips for a clean look. The shafts will run in oilite bushes for silky smoothness, the pivot block will be machined from alu and hard anodized for sexyness. The shifter shaft will be fabricated from either stainless or mild & chemcially blacked, the shaft will be made up of four pieces all welded together using pulsed TIG.
Progress will continue as long as the rain keeps fallin! It's also a good distraction to actually getting some work done!
any thoughts, comments or criticism's?
We use Bentley powerdraft here which is *****! AutoCAD ftw.So that's what it looks like, it still needs some thought about the reverse lock out actuation but it will likely be a lever of some sort to pull the pin back above the central pivot.
