I've been searching the web for a solution to my handling issues on my golf and decided to sort out some decent anti roll bar systems on the car. At the moment the car runs only the standard 16mm RARB, the standard 26mm FARB wont fit on the car because the front sub frame has been modified. I have considered using an uprated (off the shelf) RARB, but for the front there is no off the shelf option so I've decided to go down this route.
I ordered 2x medium blades, 2x hard blades with 4x eccentric locking rings and weld on collars from Sellholm tuning. Great company to deal with and they speak good English.
For the ARB tube I'll be using t45 tube. I ordered 5 metres of 32.75mm diameter tube with 3.2mm wall from proformance metals. I went for this size tube because it's slightly stiffer than a standard 26mm FARB and if needed it could make full advantage of the blades on their hardest settings.
For the pillar blocks that hold the tube I'll be using 25mm aluminium square bar machined to accept nylon bushes, exactly like on Hamish's SWB
The last things I need to source are rod ends for the drop links which I'll probably get from McGill motorsport. And I need some A31 tig rods which I'm having trouble finding at a reasonable price.
Here are the blades
Here are the blades
