Coupe GT Quattro conversion using B3 sedan stuff
  • ktel
    • Sep 2014
    • 43
    • Country: Greece
    I know that I can use every B2 quattro (including 4 door and coupe) or a B3 coupe quattro.
    Can I also use a B3 sedan quattro?
  • quattrito
    • Aug 2009
    • 739
    • Country: Latvia
    Yes you can. Mainly everything is the same.
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      you need to know that the trunk floor from a gt and quattro are not the same so everything must be swap for quattro conversion
      TWINCHARGED power,zero lag
      AEM W/M injection
      • ktel
        • Sep 2014
        • 43
        • Country: Greece
        Of course I know
        The whole floorpan will be swapped.
        Sent from my A0001 using Tapatalk
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          what are the engine plans?
          AEM W/M injection
          • ktel
            • Sep 2014
            • 43
            • Country: Greece
            Engine and gearbox from 1.8 20vt from B6 a4 6 speed manual. I will also try to fit the full suspension system of the b6 if possible.
            Just wish me luck...
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              Goodluck!! Is big step!!
              Know the feeling!
              • GazzaG60
                • 4133
                1.8 4 pot will bolt onto a 16v subframe and mounts. no body mounts on b3 4 pot.
                saloon stuff is the same on b3 except later coupe has bigger steering gaitor on bulkhead.
                subframes are same as coupe on b3 saloon. as is pretty much everything else.
                exhaust hangers are in different places.
                • andrewcoupe
                  • Dec 2010
                  • 125
                  • Country: South Africa
                  I was going to do this with my Coupe GT, But decided against it as it is very easy to stuff up the whole car..
                  you need to change the tunnel, and floor pan etc..
                  Good luck!!!
                  • ktel
                    • Sep 2014
                    • 43
                    • Country: Greece
                    Right now the car is a non rurnner, so I will take my risks...
