Lathe,mill and tools
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    Got tired of cutting and grinding 20/20mm hss blanks to get parting tools.I have an option to get a tool holder for hss blade or get to carbide+tool holder.What is your experience?I see 2 types of holders for carbide.
    I do not cut exotic materials.Use it only for the shop.To get an idea of vibrations/rigidity:Lathe is a small/medium one,750mm between centers,320mm over the ways,280 or so over the bed.Tool holder is 20mm.
    Have it for 5 years or so and never had to cut parts more than 80mm diameter.So lets say will use it more for small diameters that will require higher rpm.
    Regards,
  • De80q
    • Nov 2016
    • 56
    In my experience, I'm a machinest with 13 years experience, I would take the carbide parting blade over the HSS. Your initial investment will be higher, but they last longer and cut better. I use a style similar to the first pic you posted. It's nice to have the versatility of the adjustable blade length.
    • Thuppu
      • 4115
      I also have that type of cutter tool which in the first pic. Works decently with my small Colchester, but have to keep the rpm quite low when cutting steel other wise I get vibrations. Almost all my lathe cutters are with carbide inserts, I like them. Can easily machine some harder/hardened materials like gearbox cogwheel etc. HSS cutters could be good for aluminium if you can grind them right.
        As above we use the adjustable blade with carbide insert - much cheaper than your time used making HSS tools!
