Unheated Seat
  • Ski
    • 2591
    Unheated Seat
    Recently developed a problem with my seat heating. Passenger works fine, however, the car is blackmailing me for a new clutch and refuses to heat my seat. What should be the first things I should look at?
    Ski
    ABY Coupe
  • topsparky
    • Oct 2005
    • 2014
    Ski
    check to see if you have voltage @ the plug for the seat mat then check if no voltage the resistance of the heater element with a ohm meter .don't know what the resistance should be but if it is open circuit then the element it broken somewhere(open circuit is when resistance reaches top of the scale on your meter)
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
    • Ski
      • 2591
      thanx top sparky.
      anyone else had this issue?
      ABY Coupe
      • Stick Insect
        • Dec 2003
        • 2338
        ski look here for info
        David
        • Ski
          • 2591
          Thanx David
          ABY Coupe
          • Audi Parts Guru
            • 1317
            thanx top sparky.
            Ski, I currently have this problem as well
            • Ski
              • 2591
              No offence but that makes me feel better Let me know what it is on your side when you find out
              ABY Coupe
              • Ski
                • 2591
                Audi Parts guru did u manage to sort it?
                Ive tested the switch and that works fine. Still no heat to the bottom, or top part of the seat
                So if the switch is working fine, everything else is shared between the two seats right? (fuse, thermo fuse, relay etc.)....
                ABY Coupe
                • Ski
                  • 2591
                  Bump
                  ABY Coupe
                  • Ski
                    • 2591
                    Nobody knows what is shared between the two seats apart from the fueses? Do the seats have individual relay's ? thermo fuse's ?
                    ABY Coupe
                    • Jas11n
                      • 5067
                      Heated seats have two relays, one for the drivers side and one for the passenger side.
                      Relays located on the extra relay board beneath the steering column.
                      Passenger = relay location # 13
                      Drivers = relay location #14.
                      Both should have part number 443 919 533 A.
                      2001 Avus Silver B5 RS4.
                      1995 S2 Coupe - sold (sniff)
                      • Jas11n
                        • 5067
                        That's all the info I have.
                        • Ski
                          • 2591
                          Thank you Jas11n that is the information i was after!
                          Many thanx!
                          ABY Coupe
                          • Ski
                            • 2591
                            Im strugling to find this relay.
                            anyone know where abouts it is or what number wil be on it (not part number).
                            from what i can see, there are only 2 or 3 relays under the dash :/
                            ABY Coupe
                            • mcandmar
                              • Apr 2004
                              • 5118
                              Ski i have a heated seat kit in a box at home so i can snap a piccy of them if it helps?
                              91CQ20v - Gone to a new home
                              93UR-S4 - The Magic Carpet
                              94S2Bus - The Emerald Express
