I need the part number for the sensor at the bottom of the radiator. i think it's broken as the fan goes all the time, so i dont achive the right engine temp.
I also need the part number for the relay 13(?) caus i suspect it has retierd too.
You should achieve the proper temp even if the fan is running. That's why the thermostat is there
This could also be the "new style automatic A/C feature".
yeah i know, but i just changed the thermostat to one that opens on 87degrees. i'm thinking of changing it to a newer one that opens on 72degrees and has a hole in it so the water keeps flowing no matter what.
But, it's real annoing that the fan goes all the time. could it be the relay?
P/N sensor 191959481C 3pol or 893959481 2pol
you have a ohm loop 4470959493B on the fanhousing. and you have a timerely a 9ish pol in the fusebox too.dont know the P/N
