After-run fan relay?
  • andys2
    • Dec 2003
    • 61
    Does anyone know which relay this is, is it top left 214 of fuse box, or 214 right hand side, or none of these?. I beleive this is coming on when car is off and draining battery so i would like to take it out.
    RHD 3b S2
  • mreinders
    • 72
    • Home: United Kingdom Current: Netherlands
    should really be called the "after-fun" system
    010100110011001000101111010000010100001001011001
    011000100011010101010011001101000100000101110110
    • iain1067
      • 984
      Common problem, i would replace it but not remove it altogether
      Iain
      • Mikes2
        • 1704
        looks like this. it's under the dash on the drivers side.
        Mike
        http://www.s2-audi.co.uk
        • waveydavey
          • Oct 2004
          • 289
          I had a problem with the fan running all the time and draining the battery. In the end I had to remove the rad fan delay relay to stop it (It's clearly marked in the main fuse box). I've never managed to trace what the problem is so I've just left it out and haven't had any problems.
          Let me know how you get on. I might find out how to sort mine out.
          David
          1994 16v Coupe - Sold on and sadly missed
          1994 S2 Avant - Warmed up a bit
          1995 A6 Avant - Dag Dag Delight
          • caterpillar
            • 2480
            check out the sensor of the bottom of the main rad....it might be gone bad...it feels the temp on the rad,beside the rad hose in the bottom.
            • iain1067
              • 984
              It's usually the relay that goes bad causing the fan to come on and saty on, had this on my old s4, the fan runs pretty quiet and i couldn't work out why the battery kept on going flat until, until someone told me about the realy, i had changed the switch in the rad first plus a couple of other fan related relays and finally the after run one, which has some kind of timer in it i think.
              Iain
              • iain1067
                • 984
                I have also had a bad sensor under the inlet manifold on the water pipe too, but then that was caused by me shorting the thing out whilst trying to touch the 2 wires together to check that the circuit does actually work, doh.
                Iain
                • mdudziec
                  • Mar 2006
                  • 44
                  I've got the same problem. I tried changing the temp. sensor by the manifold butthat didn't work, or so I found out when the battery was flat one morning. I'm going to try changing the after run relay which I think has the timer inside (Part no. 447 965 571 A).
                  I just phoned Audi who want £50 + Vat for it! Does anyone know of a cheaper alternative.
                  Marv
                  Marv
                  • iain1067
                    • 984
                    I think it's audi only or vag parts maybe
                    • Mikes2
                      • 1704
                      rad fan running all the time is more likely to be the resistor pack or connections on the wiring at the resistor pack.
                      Mike
                      • andys2
                        • Dec 2003
                        • 61
                        Work-around!!!
                        I took the rad fan relay out and all seems to be well. So far so good!!!
                        • mdudziec
                          • Mar 2006
                          • 44
                          I managed to fix this problem at the weekend after changing out the after run relay. VAG supplied it at a much better price. Happy days.
                          Marv
