Rad fan differences
  • Paulgo
    • Jan 2005
    • 498
    Rad fan differences
    Anyone know the differences in size/output between a 7a, 3B and ABY radiator fan? I know the ABY is bigger and thats there’s 305mm and 280mm fans, but it would be useful to compare the differences in size, wattage etc as Im changing mine after the overheating escapade!
    I think that rad is much the same between the 7a and S2 (tho Im probbaly wrong here) - but, for instance, would an ABY fan go on a 7a rad fitted to a 3B S2!! Presumably a bigger / higher rated fan would also aid cooling?
    cheers
    Paul
