Digital speed display
    Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    Code Displayed Value
    1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
    4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
    5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
    6 Digital value of Outside Air (Ambient) Temperature Sensor
    7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of Temperature Regulator Flap
    10 Non-corrected specified value of Temperature Regulator Flap
    11 Digital value of Central Flap Motor Potentiometer (G 112)
    12 Specified value of Central Flap
    13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
    14 Specified value of Footwell/Defroster Flap
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 Specified value of Air Flow Flap
    17 Vehicle Speed (km/h)
    18 Actual Air Blower voltage (Volts)
    19 Specified Fresh Air Blower voltage (Volts)
    20 A/C Compressor (A/C Clutch) voltage (Volts)
    21 Number of low voltage occurrences, non-transient
    22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
    23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
    24 Cyclings of the switches, absolute non-fluctuating
    25 Analog/Digital value, Kick-Down Switch
    26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
    27 Coding value
    28 Engine Speed (RPM)
    29 A/C Compressor speed in rpm (Equals Engine Speed x 1.2Cool
    30 Software version
    31 Display check (all segments of A/C Control Head display light up)
    32 Potentiometer malfunction counter, Temperature Regulator Flap
    33 Potentiometer malfunction counter, Central Flap
    34 Potentiometer malfunction counter, Footwell/Defroster Flap
    35 Potentiometer malfunction counter, Air Flow Map
    36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
    37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
    38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
    39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
    40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
    43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
    44 Vehicle operation cycle counter
    45 Calculated interior temperature (internal software, in digits)
    46 Outside (ambient) temperature, filtered, for regulation (internal software)
    47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
    48 Outside (ambient) temperature, unfiltered, (in digits)
    49 Malfunction counter for speedometer (vehicle speed) signal
    50 Standing time (in minutes)
    51 Engine Coolant Temperature (ECT) in deg C
    52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the "88.8" display. See chart below.
    53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the "88.8" display. See chart below.
    54 Control characteristics
    55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
    56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
    57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
    58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
    59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
    60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
    61 Software version (latest)
    When you have finished viewing whatever code you need, just press 'Auto'/'economy' to go back to normal climate control mode....
    diamond information
