Hi pop-pickers,
As the title says, my aircon rad has sprung a leak and I gather that these things are hard to find.
My friend (who owns 2 garages
) has just ordered 3 for a fellow forum member but found that the screw threads on the 2 inlets for the pressure switches were all incorrect.
The problem is that the top pressure pipe these new rads is bonded to the outlet, rather than a screw fit and therefore I cannot simply swap my existing pipe onto the new rad.
So, BTDT's please....best solution? Best source of rads pattern or OEM (Parts Daddy?)
Cheers n
Si
The problem is that the top pressure pipe these new rads is bonded to the outlet, rather than a screw fit and therefore I cannot simply swap my existing pipe onto the new rad.So, BTDT's please....best solution? Best source of rads pattern or OEM (Parts Daddy?)
Cheers n
Si
