Aircon Dryer
  • Robatron
    • May 2004
    • 1168
    Aircon Dryer
    I've tried searching for this but havent had alot of luck.
    I need to replace the dryer on the aircon unit but I have no idea where it is or how easy it is to get to? Does anyone have any idea?
    The unit has changed so now it is R134a, I dont know if that makes any difference or not...
  • Nuvo
    • Nov 2003
    • 3826
    Hi, by dryer you mean heater and evaporator yes? If so, this is found beyond the passenger footwell, you will need to remove the glove box to gain access.
    I'm afraid that this is not an easy job by any means, as you'll need to remove the evaporator housing and dismantle it to replace the evaporator.
    Paulgo posted posted dash strip down pics recently which may be of some help to you.
    • shadquattro
      • 263
      • Home: England Current: Scotland
      the dryer is in the drivers side front wing on the pipe that runs from the compressor thro the wing, its bumper of for easier access
      skint but fast
      • Nuvo
        • Nov 2003
        • 3826
        Whoops, I appear to have been talking out of my bottom. Sorry for my misunderstanding .
        • s2driveruk
          • 12696
          location is sh&te as i am finding and even with bumper off, the bolts are tough to get too
          1992 3b S2 Coupe
            Rip it all out and save some kgs It'll just go wrong again soon when the pipes corrode or the condensor disintegrates
            • s2driveruk
              • 12696
              and in true fashion.....cant shift the drier and one of the pipes from it back to the pump has a crack in the ferrul b*llocks
              I need it working before i head off to the Ring and Le mans next month arrrrrrrrrrrrrrrrg
              1992 3b S2 Coupe
