Klima display is dead. Nothing works
  • Klima display is dead. Nothing works
    Hi,
    Before I took out the dashbord the klima display worked. When I put it back in it works to. Now its dead. Nothing works, fan etc.
    Is there any wiring diagram available so I can check if there are any relays or fuses blown ? Maybe its just the klima panel that is dead.
    I got the complete dashboard out and everything.
    Help!
    Pics
    Sent fra min SM-G935F via Tapatalk
      No tips?
      Tried with another display. Same fault. I got no power on Fuse S17 ( 30a ).
      I have removed T8F and T8E from the car and the thermo switch and everything. Put + to the fan and its works.
      Where can I see where the S17 feed is coming from ?
      Im not sure what type om diagram i should follow.
      im using this one now:
      http://s2-audi.co.uk/workshop/schema...ul91/page4.png
