Rubber rad mounts
  • Rubber rad mounts
    As per title any part numbers for the rubber bushes for the radiator ?
    Auxiliary or main rad?
      803121273 for the main rad. 443121273E for auxiliary.
      https://www.ebay.co.uk/itm/Audi-ur-q...wAAOSwGEFd55nn
      https://www.ebay.co.uk/itm/Audi-ur-q...gAAOSwkGldNtMy
        That listing for 803121273 is NOT the right part, it’s nothing like the original.
          I did think the same when I saw it but might work with a bit of modification(?), it's been a while since I had a main radiator out!
            Main rad, using a new fuel filter bush at the mo works a treat
              https://www.lspeed-racing.de/product...ler-unten.html
              Preview: Gummi - Metall Lager Audi 5 Zylinder Kühler unten
              Peter S
              1990 ErsatzS2 - Pearl/Black track toy
              1991 Coupe Quattro Silver/Black(forever awaiting a 3B swap)
              1991 Coupe Quattro Silver/Platinum
              1991 Coupe Quattro Red/Black
              1995 S6 Sedan Cashmere
              1995 S6 Wagon Silver
                Still nope.
                  As they say, a picture is worth 1000 words, especially when the part number is in the pictured part. This is the NLA lower radiator mount. My previous post shows an aftermarket alternative approximately the same dimensions
                  Peter S
                    I think I still one of those, fits well with stock radiator.
                      I recon a Mini exhaust bobbin would do the trick?!!
                      With spacer as I think the rad height is important !
