RS2 Air Con Compressor
  • mak2503
    • 235
    • Home: Scotland Current: United Kingdom
    My car is making this almighty grinding noise. I cannot drive the car due to the noise so it is stuck outside my work.
    On inspection it seems like the air con compressor has seized as there is a lot of rust on the wheel. The belt is not turning when the engine is started and there is a weird smell and also slight smoke coming from this.
    I was wondering if I could just snap the belt to the unit that way I could get the car home.
    Is there another way of doing it?
    Any help would be most appreciated.
  • CHEN
    • 329
    I assume it is making this noise with the aircon off. You can try unplugging the single wire green plug on the pump, this will disable the A/C clutch. Failing that cut and remove the belt, then get round to fixing it as and when
    • mak2503
      • 235
      I cut the belt off and it did the job. Just a bitch to get at.
      I am now back on the raod and thankfully have my car back instead of outside work.
      Thanks for the advice.
      • Jas11n
        • 5067
        Good to see it sorted, though not good that it went like that.
        Those two vids you sent to my mobile sounded horrible
        Will give you a bell sometime tomorrow.
        Jas..
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
