I was reading the Sunday Times at the weekend and was interested to learn about this bit of kit called the Kenlowe Engine Hotstart or Pre-Heater....
http://driving.timesonline.co.uk/tol...cle1429082.ece
Has anyone any thoughts on the pro's or cons for this?
http://www.kenlowe.com/pre-heaters/cars/whatwill.html
The article was claiming that the unit helped reduce initial engine wear on cold starting through warming the coolant prior to starting and also reducing fuel comsumption as less choke or over fueling was required...
I doubt their environmental claims as the electricity to pre-warm is based on oil/gas/coal fired generation in any case. But, with a view to minimise cold start engine wear I was interested.
Comments welcome.
Cheers,
Comments welcome.
Cheers,
