Umm where is this supposed to be connected to ?
  • Matt_D
    • Dec 2004
    • 515
    Whilst fitting my vacumn line to my ECU for my boost gauge i found this just lying next to it.
    Is it supposed to be connected to something
    When i pull on it the heater speed switch try to move back and forth ?!?
    '95 ABY Avant - Sold
    '98 B5 S4 -MRC400+ = 464ps 741nm
  • ian_jemo
    • Aug 2004
    • 284
    Yeah I'm 95% sure it should be connected with the heater.
    If you remove the heater you will find that it should connect into the rear off it.
    It basically controls the settings, I.e Speed, direction.
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
    • john881000
      • May 2004
      • 598
      thats correct
      its one of the venterlation flap cables
      if arround ecu could be unerblack plasitic housing above transmission tunnel
      hope this helps
      • Matt_D
        • Dec 2004
        • 515
        Ahh right, my heater does work at all speeds and with all directions as i checked but i'll have a poke around when i remove my centre console.
        Cheers chaps
