I've started getting a slight run of water into the passenger footwell of the S2 and a 'puff' of vapour when I turn the heater control away from cold with the Air Con running... It appears the water arriving in the footwell is running down next to the central footwell heater tracks. The water is odourless, suggesting it's condensation rather than coolant. (I'm hoping it's not the matrix) But where does the Air Con drain condensation from, as it appears to be worse after the air con has been running for a long time.
I'm pretty sure it's not a windscreen water leak as it's been running water even through the recent dry spell.
Any thoughts?
Many thanks in advance
Ian
Any thoughts?
Ian
