Sorry if this has been addressed before on the forum before, but just wondered if its OK for the car if I pull off the lower radiator hose to remove coolant while the engine is hot ? I'm not sure if it may put the engine at risk of being too hot with no coolant in it ? Could it warp the head, or cause other damage ?
Im asking this as i'm currently flushing the cooling system through with distilled water, and found that if you pull the coolant hose off while the engine is warm, you can get more coolant out compared to a cold engine.
So I just thought I would check before doing this again weather I am putting the S2 engine at risk ? Many thanks in advance
