Audi S2 Avant ABY - Ar Condition completely Remove
  • BlackBullet
    • 146
    • Country: Brazil
    Hi Guys,
    First I have just one problem at my Air Condition. It´s a leak at the Absorber... So.. To change it, I need to unassembly the panel... than I should unassembly the Air Box, where the Heater and the Absorber is located!
    At the ELSA have this instruction:
    It´s DONE!
    It´s DONE! But the V87-1018 doen´t came out!!!!
    The picture now is:
    What should I do to take this box out???
    Someone can help me???
    Thanks,
    Rafael Pinto
    Audi S2 1994/1995 Avant - Black
    Audi RS2 1994/1995 - Black
  • Skull
    • 3506
    • Country: Slovenia
    I can help you. There are 2 bolts that hold the klimabox fixed to the firewall. Second pic, under the letter A, there is one more something like 20cm under this bolt. Then remove the air filter, and there yow will find 2 more bolts to undo. Inside the car, there are some screws and nuts holding the air ducts.
    Audi Quattro WR
    • BlackBullet
      • 146
      • Country: Brazil
      Hi Skull, I was travelling, but now I´m back!!!
      So, on my second picture, there are 2 bolts named A... this 2 bolts its done!!! There is one more at the side... should I take this bolt too?
      Among 20cm under them, I did´t see any bolt.. have you a picture?
      The bolts at the air filter are out.. and the right side from the klimabox is free... my problem is just the heater... something I don´t know where is fasting it!!!
      Can you help me?
      Or someone?
      Thanks,
      Rafael Pinto
      • Skull
        • 3506
        • Country: Slovenia
        Look at the A bolt, there is one exactlythe same something like 20cm under the A bolt. If the klimabox is moving, then the top of the heaterelement is stuck against the horizontal pillar above it. Just pul like u wanna destroy everything
        Audi Quattro WR
        • BlackBullet
          • 146
          • Country: Brazil
          Hi Skull,
          Here am I again!!!
          So, let´s go step by step!!!
          It´s an Allen M10 screw... Done!!!
          Under the Air filter... more 2 screws... Done!!!
          Here is the 2 Bolts that is named "A" at ELSA, and the other one 20cm under... DONE!!!
          There is 2 little screws on the left circles of the picture... They are OUT!!
          The Air pipe to the back seats... is unassembled as the 2 bigger circle!!!
          Rafael Pinto
          • BlackBullet
            • 146
            • Country: Brazil
            At the passenger side, there is a hose that carries water from the heater matrix! It´s OK too!
            At the drivers side... there is a screw near the accelerator pedal, it´s no more there! (the left red circle on the picture)
            I have pulled it out.. it cames a little more.. but.... I guess that I forgot something... some bolt.. because it doesn´t want to came out!!!!
            I hope my problem is just at the heater area... something that I need to do to get more course to pull it out!!!!
            Could you help me a little bit more???
            Cheers,
            Rafael Pinto
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              I had this problem. The recirculation actuator vacuum hose snagging on something. Have you disconnected this small vacuum hose?
              SS
              • BlackBullet
                • 146
                • Country: Brazil
                this recirculation actuator should stay on the right side, isn´t it?
                My problem is on the middle!!!
                Rafael Pinto
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  It's a small bore plastic vacuum hose that goes through the rubber grommet with the A/C hoses to/from the evaporator, where you removed the M10 Allen screw, that's the only thing I can think of that you have missed.
                  SS
                  • BlackBullet
                    • 146
                    • Country: Brazil
                    that side is absolutly free... (the evaporator side)
                    This hose would not block the central part.. the heater box... At the heater box... is it all done? There is no more bolt that need to be unscrewed?
                    Rafael Pinto
                    • BlackBullet
                      • 146
                      • Country: Brazil
                      DONE!!!!
                      Rafael Pinto
                      • Skull
                        • 3506
                        • Country: Slovenia
                        That was nothing holding it in. Maybe the heater core was stuck at the top, like i already mentioned, or the AC pipes were stuck. What was it?
                        Audi Quattro WR
                        • BlackBullet
                          • 146
                          • Country: Brazil
                          It was just space to take it out...
                          I have unassembly the airbag sensor and than I could pull it.
                          There was little hose behind as mensioned, the vacum line, the central plug for the air condition ecu.
                          Now its out.. and I have changed the evaporator!
                          I want to thank you skull and 4WhellDrifter for your help!
                          Cheers,
                          Rafael Pinto
