It seems that my RS2 is having some issues concerning the A/C.
When the A/C is turned on,i have an extra engine sound that elevates along with rpm which it didnt have before.We have used 700cc of a/c freon fluid,and the cold air is very good.
However as the a/c turns on,the engine temperature comes very high!! I saw 3 lines over 90 degrees again,then engine oil elevated as well,and oil pressure dropped near 1bar on idle.It seemed as if i was running in a circuit or a track day!!!
When im on an open road doing 120-130Kms the temperatures are fine.
Im thinking that i may have a compressor issue,or a A/C radiator problem.
I wanted to ask,is the coolant water running through the A/C radiator or freon(A/Cfluid?)
if the radiator is blocked,could this be the problem of the elevated temperatures and still have cold air blowing in?
thanks
Vasilis
thanks
Vasilis
