Had Klausy pop round today to top the aircon up on the S2, rather handy having a quattro friendly AirCon and windscreen repair specialist (Klausy's putting a 20vt into an 86 Ur quattro). Did a superb job on the S2, it'd been re-gased at a dealers after the Heater Matrix Change and only partially filled, after a full vacuum and complete refill the Aircon is painfully cold now.
Well worth giving a bell
07973 252531
93 MTMS2 Avant
The Perfectionist
Just had my AC fixed.
Pipe replaced, new bearing in the compressor, new condenser, re-gas.
The guy did a fantastic job, and was very reasonable on price!
So if you're in Edinburgh, call David, Stable Air, 07771538360
John Bowlerwell
Electronic Engineer
Present:
Nogaro Blue RS2 - TOE
Previous:
Kingfisher Blue S2 - UAA
Volcano Black RS2 LHD - DEX
funny I was looking at Aircon just yesterday, most of the S2 Systems were R12 systems which have to converted over to R134a, depending on who you talk to this can as simple as draining and flushing the system and changing the oil and re-filling with R134a, or you need to strip down the whole system and replace seals and some of the pipes as R134a has smaller molecules and just leaks out.
I did a bit of digging and basically if you can find anyone that uses it, that you can switch from R12 to R49a, and that R49a is a drop in replacement for R12. The drawback is that most AC texts say that you have to go from R12 to R134a.
Most aircon companies mention R12 and some drop in solution rather than changing to R134a that i have seen. If nothing is mentioned on the ones you have found give them a call? Mine is going to cost £70 for a full refill etc.
Have a look on www.caraircon.co.uk and should be able to find someone local to you to use?
